boriqua_n_co
I recently purchased a set of Pilot Road 2s and I was wondering if anyone has used a set at the track?? They do have the 2CT logos so I wonder of they are as good as the 2CTs??
I have a similar, but yet different question:
I just fitted a brand new Michelin Pilot Power Pure front to my Busa
The rear is still Pilot Road 2
Any caveats on track days?
not for straight line braking, but on a lean angle yes: trouble waits me...
I was just wondering how much the breaking distance shortens with a softer tyre and how much shorter the mileage gets...
"Braking" performance is dependent upon weight transfer, not tire compound. You can lever the rear tire off the ground with a sport touring tire in a hard stop so therefore your deceleration rate is as great as it's gonna be regardless of tire compound.
cheers
ken
cheers
ken
You really shouldn't mix and match sport tires with touring tires. You need that grip on the rear too!
Oooooooooooh, my dear friend you may want to re-think that statement! lease:
I think what you meant was one shouldn't mix and match tires from different manufacturers?
I have a number of friends who run a dual compound touring tire on the rear with a performance tire on the front. I will be installing a BTO16 front and a BTO23 rear on my busa soon. This combination will give me longer tire life while still giving solid performance for those brisk rides through the canyons as well as wearing out the front and rear about the same time!
The idea is to keep the front planted. One can tollerated tire spin on the rear but the most important is Braking grip as well as side grip on the front. Personally, I am much more concerned about front braking grip in emergency situations than side grip on the twisties!
