it is alot easier first drain engine coolant remove oil cooler and radiator as 1 peice i would change oil filter since you have everything off i would also use water wetter and honda pre-mix for the coolant when you re-install everything leave plastic off so you can warm bike several times so you can re-fill radiator so there is no air in system
right on, thanks (looks fun 'eh eddie?) - hope my block off plates get here quick while i am inside this thing (cheese wazup?) - will do it that way and remove everything.
It is easier with the Radiator out of the way but I have done it with it on.
The oil cooler I remove with the hoses as well I remove the oil filter to remove the black bracket for the Pair.
then reinstall the filter.
Jason, They went out on the 14th I guess 2-3 days.That is how long my child support check takes to get there
[This message has been edited by Johnnycheese (edited 15 June 2000).]
