i have never heard of spark plugs causing smoke. now, if there is oil, or some fuel additive, or perhaps a fuel contaminant, or maybe even coolant getting into the combustion chambers... now that could cause smoke when mixed with the fuel charge, and then ignited by the spark plug.... someone else asked if you had new exhaust? new exhaust could have fabrication residue that is burning off. another thought is that you might have something coming into contact with the outside of your pipe. external oil, coolant, part of the fairing, anything combustible touching the pipe, including smudges form cleaner etc.
i think that you need to narrow down the problem so that sensible solutions might be offered.
nothing touching the pipe? it does not smoke when running? no leaks that could be getting on the pipe?
pull the lower fairing and inspect?
anyways, good luck, there are a ton of qualified busa mechs on this board, and with the right description you will surely get help. ???
