The AFR reading was two years ago....I couldn't remember the number. My point about the AFR is that the tuner which used to be a reputable tuner in the drag race industry, having his own team and everything, said that the AFR was where it was supposed to be. As I cannot remember the EXACT number, let me assure you that, it was close to what it was supposed to be. I didn't want to give an erroneous number off the top of my head. I am very comfortable with this tuner, unfortunately, as far as I know, his services are no longer available.
500 rpm increments vs 250 rpm increments don't mean much to me. There is a function in the PC software that can expand the map to 250 rpm intervals easily. I could've just easily posted that picture instead.
As for the 2%, partial mapping, other than no fuel being added or taken away above 5500 rpm, unless that is what you are referring to, I don't know how you can tell this is an incomplete map...Unless you provide maps that are from 500 to 10,500 maps for each throttle percentage.
So to get back on point here, my real question, after comparing several different maps, is how are so many full exhaust system apparantly pulling fuel out throughout the range, when the assumption would be more air, more fuel?
