Please help with the f1 code
money mike
:banghead::banghead::banghead:
Hey guys, new to the board and having that f1 crap!!!! i saw it on here a while ago, but couldn't find it this time around... will someone please help me get into dealer mode... last time, i couldn't find which wires i needed to do it to. Thanx alot in advance!
Money mike,
Rubber side down!!!
Money -
Under your hump on the left side (somewhere between the pilot's seat and the tail) there is a smal white connector with a black cap. That is the dealer connector; if you insert a paperclip into the two holes to "jump" it, then crank your scoot, but don't shut off the power until your code comes up, you should be able to see exactly which code it is. Hope that helps, MCM
