Ok, so I took my rear tire off last night so I can get a new mounted today. After pulling the wheel, the sprocket and outer-hub fell off. Never had that happen so I looked around at the cush drive and seen the rubber pads inside have smoe wear on them, like they were being ground or cut by part of the outer-hub. There are little crumbly spots of powdered rubber inside the hub, but couldnt really tell what caused it. Is this normal?
I think my chain is in serious need of cleaning also. Not sure if it normal for Busa owners around the SW, but this chain has a very thick coat of some serious sticky lube, worse then I ever used on my dirtbikes. I was wondering if maybe because we go from Monsoon rains to blowing desert sands that maybe its recommended to use a thicker, almost like tar, lube?
