Power commander accel pump question
Dopey
So I just installed the brocks exhaust and map on my buddies 2019 and from what I can tell he's saying he's having an issue when he's hitting the throttle or lags before power comes on. I've of course told him to get out on a dyno but until that can happen I was trying to see if there's anything I can do. One of our new members and I were having a conversation and he brought up the accel pump feature so I'm curious if anyone has set it up on their pc5 and if so what they set it at. Also since I haven't hooked up the laptop yet curious if that's something that may have already been setup with the brocks map I installed. I'm just learning the power commander stuff so any help would be much appreciated.
So with all the knowledgeable folks we have around here and all the power commanders that have been installed thru the years I really expected someone had used this setting before and would have an idea of what to set out at to start. So far I've only tried one of the maps I loaded on my own power commander fc (thanks for an awesome price @P33rob ) and luckily I don't seem to have any lag but the map I'm running did seem a little rich as it was "smoking" when I would hit the throttle off idle but the fc allows a little fine tuning like the old pc3 so I turned the low down a little and that went away instantly.
Accel Pump Configuration
The Accel Pump feature adds extra fuel when the throttle is opened rapidly.
Go to Accel Pump and click on Configure. The Accel Pump Configuration box will open.
The grey % Throttle box displays whatever percentage the throttle is currently open. The % Delta Throttle displays the throttle position Accel Pump is programmed to be activated.
Click in the Trigger (% Delta Throttle) box and enter a number between 1 and 100. 1 is most sensitive (most likely to trigger the accel pump feature), 100 is least sensitive.
Click in the Duration (Revs) text box to enter the number of engine revolutions you would like extra fuel to be added when the accel pump is activated.
Click in the Fuel Adjustment (%) text box to enter the percentage of extra fuel you would like to have added when Accel Pump is activated.
The Capture button may be used in conjunction with live application of throttle to select a delta throttle position rather than inputting a value in the Trigger box.
Click OK to accept the present data entered in the Accel Pump Configuration box or click Cancel to close the window without changes.
X out of the Accel Pump Configuration box.
The above is my writing, not DJ's.
My bike with the PC5 is my Gen1 ZX-14, not my busa.
I don't see a reason add fuel when the throttle is opened rapidly only cut it off after a preset duration of time. The fuel and the throttle position should work together in the map regardless of how fast the throttle is opened. If the bike isn't tuned, you're just taking a guess by using accel pump. ...but why not give it a try?? I have never tried it but I have a friend who enabled acell pump on his ZX-14 by the recomendation of Ivan and he said it's great. ??? I don't see the purpose.
The In-Field Fuel Adjustment function of the PC5 is also not very useful.. It's a crude way of tuning by guess. DJ told me some people find these things useful on snowmobiles where they experience a wide range of temperatures and other conditions.
