to the oRg You don't need or want a TRE definitely unleash that ECU. There's people here that will let you mail it to them and they'll do it for anywhere from $0-50
Not wanting to sound like jerk, there is a different between Unleashed and flashed.
ECU Unleashed is the tradename of a company that reprograms ECUs with a parameters they have developed that may or may not be correct for your setup. If you need to make changes it has to be done by them again.
Reflashed is done with the ECU Editor/Woolich programs where about anything can be tuned and changed as needed by your tuner.
For the price of a TRE (which is a POS) you can have it flashed and have access to the 6th gear fuel maps which you don't get by using a TRE.
