if you add the hub kit you WILL get a gear position as well as a speedo and boost gauge. But you HAVE TO GET the hub kit to get the full function of the LCD screen With out it you will only have the stuff the power commander gives. RPM, injector duty cycle, fuel meter and map selection.
Let me know if you need one, Ill hook you up.
Josh
Ryders Connection
