power commander question
1473hayabusa
i have a 2007 busa with a power commander with a brocks map,the stock ecu has been set with a teka tool, do i need to zero out the ecu before using the power commander and brocks map. thanks
k, looked it up. i'd say ditch the pc and pick up an ecu flash harness from boostbysmith.com
just curious, how can you reset the ecu?
yes you have to have them reset the ecu with the TEKA box and hopefully it will be close to zero after they do it but.....I would still put the map in and have it custom mapped just in case
