Not yet. It seems to be a little easier when explained in forums.wow, lots to say there.
have you tried the search function yet??
Its running great. I don't want to mess with it. I want to get educated on what it does. I plan to dyno soon.Its hard to give any answers without specific questions. Is your bike running good?? If its allready installed, are you trying to mess with it or just learn about it?? Are you planning more mods?? Are you planning on tunning it on a dyno??
I would say to exploit the full potential of you existing mods, you need the PC3 usb.With atleast the map for your mods if a custom tune is not in your picture.Hi Guys, I dont have a PowerCommander, but when I took Bike for Dyno they plugged Yoshi box in and did some fine tuning and then removed the Yoshi box again.....
My question is - Would @ PC make a BIG difference to my bike?
Have Full Yoshi Tri Oval System and Airbox Mod with BMC filter...
Thanks in advance
Yup .. you most definetly need a PC3 if you are having those modsHi Guys, I dont have a PowerCommander, but when I took Bike for Dyno they plugged Yoshi box in and did some fine tuning and then removed the Yoshi box again.....
Thanks in advance
Thanks for the info.There are a whole bunch of things to know about the power commander! I suggest you go check out the www.powercommander.com site... its quite informative, and has a lot of .pdf manuls to install and set up the PC3
Your most welcome ...Thanks for the info.There are a whole bunch of things to know about the power commander! I suggest you go check out the www.powercommander.com site... its quite informative, and has a lot of .pdf manuls to install and set up the PC3
