powercommander or not?
busa_no1
Do i need pcIIIusb or just retune suzuki ecu?
does pcIIIusb gain more power and torque?, better motor running? or better fuel economy?
I had -05 busa with yoshimura trs full race, pair-mod. and maybe coming yoshimura stage1 cams.
thank's anyway!
Welcome to the board.
If you have some aftermarket exhausts ... the PC3 will really make sense in increasing HP. You can install the PC3 on a stock Busa also, but it will not increase the HP. It will just smoothen out the power deliver.
If I understand your post correctly, yes you do need a PC. A full system makes it a requirement to get the most out of it.
Thank's for infomation.
I do have yoshi full race exthaus on it and the broblem is that someone says you need only retune suzuki ecu and the other says yes you need pc3usb.
I'd like to hear some fackt from guy's who drive's with pc3 and full exthaus on his busa and how it runs?
I'm also interested of how much power you can get out of busa wiht those light modification like exthaus and pc3 or suzuki ecu....?
what about yohsimura stage 1 cams?
<!--EDIT|busa_no1
Reason for Edit: None given...|1112008353 -->
As far as power numbers, I will be taking my Busa to the dyno hopefully in the next month or so to see what I gained in installing a BDE Gen3 with a PCIIIr with PAIR and airbox mod also. I'll let everyone know my numbers.
