what kind of radar detecters are you guys running on the busa's? I need to do this as well because I have a cdl, so any help I can get would be appriciated.
And it'd be nice to keep it too
Mine (Valentine V1) is hardwired to the battery, but since it's mounted on my tank-bag for easy carry, it energizes when I plug the power-cord into the back of it.
Works just fine with no additional mounting hardware and it grab-and-go when I walk away.
FWIW I connected my power wire to the low beam headlight and I used one of the gauge cluster 8mm mounting bolts as the ground source. It powers on and shuts off with the key.
Pad, that sounds like a very good way to wire up the radar detector. What did you use for a mount? Did you make one or is their some place I can order one?
