TapRackNGo
OK,
So I put a new 16T sprocket on while the cover was off I knocked the rod loose and clutch fluid came out. Placed everything back together, and clutch has no pressure. I tried to bleed it, fluid comes out but still no pressure in the clutch. I took everything apart and put the rod, spring, back in and it was full of fluid which dumped out. Again I tried to bleed, which I got fluid to come out, but still no resistance with the lever.
Any Ideas?
Need help asap as I am riding tomorrow.
thanks guys
Any Ideas?
thanks guys
