problem with lean engine and expensive map gas
gardobusa-pr
hi i clean the injector and habs of gas tve aeromotive fuel pump and reg have 50 lhe engine have 1mm both valve 2mm stroke portinghead and 240lbs compresion i will like now if i need change the injector thank for help me
you need to take the bike to a dino machine and have the ecu reprogrammed. this will fix your lean issue probably.
