Hello...It has a while since my last post. As we know the busa's throttle takes a bit more twist to obtain WOT. Over the years I've read where riders are having trouble attaining WOT. I personally didn't care for the amount of travel so I modified mine into a progressive throttle. A word of warning this is a no BS approach and unless you have very good throttle input control and an experienced rider don't even consider this mod. You will end up in a world hurt! I started out by marking the "wheel" on the shaft connected to the throttle bodies. At half throttle I started a layer of hard silicone in the valley. I built the bead up until the achieved amount of travel "twist" and progression was attained. You can customize to your own taste and remove it at will...and let me tell…when you get it personally tailored. You can snap the throttle open faster then a blink of an eye. I had a few people jaws drop after that mod and commented how “that thing just explodedâ€. BTW- First gear was interesting to say at the least but I could feel where the progression began and applied input from there. Hello to everone who is left from a while back. Like I said this is a NO BS mod and you better have your act together.
<!--EDIT|Dulimon
Reason for Edit: None given...|1151099814 -->
<!--EDIT|Dulimon
