Push pins fitted correctly
dave s
Hi guys, I've had the bottom pannel off to change exhaust and cannot remember which way the push pins fit
Pannel into bracket or
Bracket into pannel
I know it's a silly question but it bugs me if it's not right
1619172
1619173
What usually confuses me is whether the plastic tab goes inside the metal or outside. Looks like you have it inside on the right and outside on the left. I'm sure the tabs both go on the inner surface of the bracket. I put the button facing out like the others said.
Well noticed Mythos ,out I go again to pull the pins
Plastic goes inside the bracket.
