I just finished my HID install, put everything back together, and went for a ride after dark.
They needed adjustment so I pulled the gauge cluster. Putting it back together, the large pins holding the lower gauge trim piece will lock but not hold (they fall out). The panel and surroundings are perfectly flush with one another. All the wiring was run behind the gauges so as not to interfere. I even tried new pins but to no avail.
What should I do? The center hex will hold the panel in place but cosmetically there are two holes there.
