Quasar's Map
nitrousjunkie
60 Years Young And Still On A Busa!
Finally got around to loading Quasar's map tonight,just got back from a spin down the road.This map is right on! The main difference between this map and the previous map is in the accelleration.While going through the gears at wide open throttle, the bike is stronger than before.There is not one flat spot or backfiring,I told him I still had the pair still intact.For $25,I very impressed! NJ.
Been thinking about getting me one of these and then seeing how it does before I go and get a custom one done at a dyno. Good idea or not?
The best spent 25 bucks I've done in a long time! I just thought the bike ran good before,the power through every gear is awesome! Its got a different sound now under heavy accelleration.PM the guy, what do you have to lose?
Hey nitrousjunkie, were can I get a map for my 05 busa like the one you have, that I will not to have to remove the pair and have the throttle response that you have on your bake, I will appreciate the help, thanks in advance.
PM This guy named Quasar over on sh.org, he's getting 75 now due to non payment of what and I quote " 95% " are non payers. NJ.
This guy knows how to write a map,It's unbelievable the improvement over what I was running,He's a nice guy as well, so give him a try,at $75, its still a bargain.NJ.:)
<!--EDIT|nitrousjunkie
Reason for Edit: None given...|1124215538 -->
Quaser's MAP are the very best!! They made Elenor run like a toatally different bike
$75 is also not too big a price for his MAPS
aRE YOU GUYS RUNNING PCIII ? i HAVE ONLY SLIP ON YOSH, ANY OTHER MODS REQUIRED ? THANKS gUYS !!
I have bolt-on Microns, PCIIIR, PAIR valve removed and small airbox mod. The map he sent me works like a charm.
