question about tire
dsmdave
hi to all just question about tire, last couple week i got puncture in my rear tire. i put the plug in and been riding for couple week now, should i change to the new tire or just keep riding. any safety should i concern about? it still had 60 to 70% on the tread left. any comment or suggestion? thank in advance. this site is best i learn a lot from it
It is up to you what you do but I would Ride it just don't do allot of high speed runs and it should be OK.
Most everyone on here will tell you to trash the tire and buy a new one. If all you have is an externally applied plug, take it out. Not only the fact that they leak, they have a tendency of working themselves loose and falling out all together. I work at a tire store and once used a patch-plug that is glued on the inside of the tire, it held just fine. I would say replace it. Good luck.
Replace it. Safety should always be first. I have plugged tires on my Maxima, but even in the M3 (low profiles) I replace flats. Is your life worth a little more than $200? Mine is.
thank all you guy for reply, i think i will replace soon. when you riding a fast bike kind the hard to stay at low speed. that my 02.
In the middle of the tread, a hole not a cut, a rope plug will work fine for running to close to wear bars! Carvin up the canyons or a dragon slayer, Hi speed runner, it will be on your mind allways! I don't give it a second thought anymore I've done it so many times.
I plug them when on the road but pull tire and patch on the inside at first chance. If the tires old I'll replace but if fairly new I try to get my use out of it.
