Question about welding clutch hub
slider_buck
im about to weld up the back torque eliminator but have a question. do you want the two pieces flush with each other or should i weld them up the way they set in the clutch basket? ive seen them welded both ways. just wondering which is the correct way. id think under normal conditions the two pieces would be flush with each other.
