blitzburgh
Last year I installed a fuse block in the tail of the bike. It looks like this..
ImageShack Links Do Not Work
I have it running right from the battery to this accessory fuse block. My question is what would it take to change this setup so that it will only get power if I turn on the bike?
Im starting to rack up quite a bit of accessories and I don't want to power everything all the time and run down the battery.
If this is to much I might just do option 2 and get a "plug and play" from boostbysmith and use both. I don't think I can run just the plug and play wire with the following hooked up to it..
Sirius radio
GIPRO
LED light set(just order)
PCIIIusb
Air Shifter(still need to get)
If anybody has some input it would be very much appreciated...
Blitz..
Sirius radio
GIPRO
PCIIIusb
Blitz..
