Question on GSXR 1000 VS 1300
I have a Busa and a 1000 Gixxer. At a distance they may look similar. But they are brothers from different mothers... As Mr Brown said. No and no again.
Popie -- how about the engine mount (near the top of the head) is the 1000 the same location as the 1300??
Aaaaha!!
I know what you are thinking . . . you wanna fit a Busa motor to a GSXR1000 chassis . .
right??
Good luck . . .
Here's a Gixxer thou with a Busa motor . .
well, I've been doing a reverse trike, I'm afraid my 1300cc way too much and flex my chassis. I was just thinking to go down to 750cc or 1000cc but my chassis motor mount was already set. I was asking if the 1000 the same motor mount location like the 1300.
Way too much what? The only thing significantly bigger about the Busa motor is torque output. Which you're gonna need in your application. It's not much physically bigger, doesn't weigh much more, and they make roughly the same hp, depending on what 1k you use.
i WORRIED that it might overpower my chassis and flex it during hard acceleration.
I think 750cc is ideal but I already have the busa engine. I guess I have to experience it and see how it works
It'll only do what you tell it to do. If you're worried about frame flex, gusset the frame or don't whack the throttle....
