Road Weazel
I have recently purchased a '99 Hayabusa with a Hahn Turbo, Water Injection and a Halmeter AF30 gauge. I apparently misunderstood the seller and thought it was a Port Fueller but it is not. I have two fuel pumps and two inlets into the fuel rail. Most of the build documentation is lost but I have some and it would appear that the larger fuel pump will run up to 80 PSI or higher as RPM increases. I found a note in my pile of paperwork that suggests 46 PSI of fuel pressure at 2K RPM, 60 PSI of fuel pressure at 4K RPM, and 76 PSI at 6K RPM. The injectors appear to be stock. I have a PC II but I don't have the input cable so I may be switching over to a PC III USB. I have fouled my sparkplugs in only 3 tanks of gas or so, all highway riding with very few short bursts on the boost. The Halmeter always reads 'full rich'. I have leaned out the mix on the PC II with the push-buttons and I'm thinking about lowering the fuel pressure on the bigger pump. I'll watch the A/F meter carefully on my test ride. I'll schedule some dyno time in the near future for a better tune.
Big Fuel Pump - I'm guessing that the screw and locknut on the top is the pressure adjustment?
Second Fuel Inlet to Fuel Rail
Smaller Fuel Pump
On to the Water Injection.
The water pump is directly in front of the ram air duct, I would guess for cooling. Does it need to be here? I'd like to move it under the tail cowl where the charcoal canister currently resides. Changing #3 and #4 sparkplugs is a real PITA with the pump where it currently resides. Would there be any issues with moving it to a place where it gets less direct air flow?
Thanx in advance,
Weazel
Smaller Fuel Pump
Thanx in advance,
Weazel
