Quick ABS question
BusaBenny
Hello everyone. I have a 2017 Hayabusa with ABS. I need to bleed the brakes. Is the process any different then a 2008 with no ABS? Thanks
Is the abs pump open at rest?
I assumed there'd be some procedure to open the valves to allow bleeding?
Something else I just learned today.
After watching the video Brian made the other night and actually seeing the abs module it reminds me of the early Chevy abs modules that you needed the scanner to activate and bleed out the module. And honestly the way the stock lever feels with a quick double pump is the same as when you'd have to pump the brakes in the chevys. So knowing there isn't a bleed point on the module is there a way to activate and bleed it? Just seems like a good place to get an air bubble stuck to me. Just a curiosity question.
