Quick Oil Question
kennym4
I just changed my oil, 2006, drained overnight, put 4 qts. and it's reading full.
I started it up and ran it up to temp and now it's just barely under the full mark? It says 4.7 qts to refill?
Owners manual sez 3.7 quarts if you change filter.
One of the things you hafta watch out for is the engine holds a LOT of oil above the sump or oil pan and it takes a good while to drain down. Do NOT adjust oil levels until the bike has cooled and you've allowed ample time for the oil to drain down..!! If you put 4 qts. in you should be good to go.
Should I just loosen the plug bolt, and let a little out then add some till it's just under the fill line ? Or is 4 qt.s okay ?
I just let it be. First time I did my own oil change, feels kinda good. However for a minute I woulda paid someone $30.00 to put my plastic back on, LoL
Thanks !!
Thanks !!
Gets easier the more you do it, never actually easy tho. Thsoe shiny parts relly like to scratch each other
