Quickshifter using ECU
smithabusa
Site Sponsor
I just put 2 of these together for Len in South Africa
Could have got pre fabbed up shift rods, but customer wanted to make them himself.
Wide open clutchless shifts, just pull up on the lever and let the ECU kill the engine for you :)
ECU Quick Shifter :cheerleader:
Does it have to be a WOT shift and can this be used for other than racing?
i would highly recommend wot shifts or hard load
same like an air shifter i wouldn't use it to put around town and shift. Each time you put pressure on the lever to pull up it would kill the engine, but i would still blip the throttle or clutch it when the engine isn't under much load etc
Thank you Sir.
this is expensive, the darn pressure switch costs almost $200 for a cheaper one, don't ask me why they cost so much LOL.
If it were me I'd go with a Co2 shifter from cycle-tek.com and replace the kill box with this ECU Air Shifter Harness
