R1 Throttle Tube?
Ham
Ok so i did the R1 throttle tube modification when i removed the cables from the tube it self i can't remember which one goes front or back. I'm thinking the one with the cushion goes in front see pic. Can someone confirm this.
Like sjg said you will know right away if you have them backwards no big deal just switch them. Make sure you try the throttle before you put everything back together.
Thanks guys,I checked everything and also for a pick i had to confirm that it is correct. Really tightened up the throttle.
