Radiator Coolant Flush
JZ7355
Do I need to flush the system with distilled water or can I just use a garden hose. If I need distilled water, where can I get it?
Yes you need to use distilled water to flush.  You can get it at the local Super WalMart or grocery store do not use your water hose it could put mineral deposits in your radiator. Also recommend replacing the coolant with engine ice runs a little cooler.
Do you mean fill it with distilled water and run it ,till warm then drain it (cooled no pressure), and fill with 50/50 mix
