I was thinking of putting another fan on the busa . Will 2 factory fans fit? Just wire them together? Overload? I have a Muzzy on it now, & while the bike is apart ,I thought I'd upgrade...
just did this mod last weekend using the Gixxer 1K fan and it turned out fine.
tremendous increase in air flow.
be sure to tilt the radiator forward during install for a bit more working room (It's still very tight working but it does fit).
thanks to BusaCruise for his pinned post on this mod.
don't do what I did. both fans share the bottom center bolt and I only started a couple of threads while I was figuring out what I needed for the second and third mounts.
when I had everything together I realized I forgot to tighten down that center bolt.
the Mrs saved my bacon with her small hands, got in there herself and finished the project. What a woman!
Tha fan I have is off a 2006 gsxr 600.. All the blades are connected as one unit .Looks like the shroud is made in the blades ..I didnt see any fan listed foor that year?
