they don't lower the front end. They are a spacer that goes under the triple tree allowing you to slide the forks farther up in the fork tubes which in turn lowers your front end.
very easy to install.... 4 bolts on the triple and insert risers, reinstall new longer bolts.... bout a 15min install.
