And remember to put the cotter pin back in. I didnt and the nut tightened itself and had to use a montsrous 3 foot wrench and step on it with my body weight to get it off....
I recently bought a bag of 100 cotter pins from Fastenal for like 5 bucks so I never run out when I break them and have to replace them
Does his bike use a cotter pin ???
Posted via Mobile Device
Yes, 36mm. Do NOT use Imperial sockets.
Yeah me too... And i use a torque wrench so i KNOW i did not tighten it more than 72 ft lbs.wow. i figured it would work itself loose not tight.. that would have been something to see you bouncing on that wrench lol
+1 36mm definitely 1/2 in drive and get a breaker bar (life saver lol)
That's what rattle guns are for.
EDIT: Russell, how does a cotter pin stop the nut from over-tightening? Do you have holes drilled through the nut itself?
Cant tell if it is a Gen2 or not. If i had a Gen2 I would definitely mod it so it had a cotter pin though...
On the GenI it uses a castle nut with slots for the cotter pin.
I think that must be an aftermarket part, because my '06 does not have a castle nut, nor does any other other Busa I have ever seen. Ever.
