All you have to do is turn the front to the left. line up spools or swingarm with stand (stand will be on one wheel. Then I stand on left side of bike and push the stand down, as stand flattens on ground bike will be held there. I usually put my hand on hump or hole in side of rear fairing for support if I get nervous. Once the stand is in position and the bike is vertical, all you gotta do is push it down slowly. It won't fall over. Then to get it down, I lift stand till rear wheel touches, then I pull back on hump a little until kickstand touches the ground, all the while pulling back a little so the bike comes down on the wheel and kickstand.
Sounds more complicated in type than it really is when you actually do it.
<!--EDIT|thebbbusa
Reason for Edit: None given...|1149987822 -->
