rear brake line
Yes, loosen the banjo bolt on the stock line at the master cylinder and point it towards the rear! Tighten bolt and bleed air out of line! Hope that helps.
(05BusaLe @ Apr. 25 2007,01:04) Yes, loosen the banjo bolt on the stock line at the master cylinder and point it towards the rear! Tighten bolt and bleed air out of line! Hope that helps.
+1 ....just use the stock....I'm a +8 with the stock line
(05BusaLe @ Apr. 24 2007,23:04) Yes, loosen the banjo bolt on the stock line at the master cylinder and point it towards the rear! Tighten bolt and bleed air out of line! Hope that helps.
05BusaLE:
I've never bled the brakes on anything. Could you point me towards a tutorial on how to bleed the Busa brakes or maybe give me some advice?
Hey 1300 .. thanks for asking. I was going to ask this in about a month or so when I lower and add the extensions to my bike.
or if your going s/s lines speigler makes them to custom length and ends, had to get a custom one for my R1 after changing rearsets.
