Like I said in my first post, after reinstalling everything last spring the rear brake was very weak, but I wasn't overly concerned about it. My very last ride of the fall when I first started out the bike felt weird, pulled into a parking lot and the rear rotor was fairly warm (not glowing or anything) from the brake dragging (had only gone about 3 miles). Anyways, messed around with it for a few and it was fine after that, felt as it had all season.
So today, just a quick ride up the street and back, slow down to turn back into the driveway, rear brake feels solid at pedal. When I checked it out it seems there's very little movement up and down on the lever and the lever doesn't want to return to the up position without some help.
I don't think the pads are dragging now or anythings warped because when I started the bike while up on the stand in neutral the rear wheel was slowly going around, if there was any friction at all I'm sure it would have stopped. It seems the binding is either in the piston thingy mounted to the rearset, or a bind in the lever itself, but the lever returned fine all last season.
I didn't have a lot of time to look at it as it was time to go to dinner. Is there a spring or anything attached to the lever that brings it back up or just the pressure from the brake cylinder?
There's definitely NO leaks anywhere, everythings dry, that's one of the few things I did check.
Might just have to pull the lever and all off and see whats to be seen.
Thanks Dab
