Rear Caliper Banjo Bolt--How?
Mythos
There is some sort of bullet head on the rear caliper banjo bolt. How does that thing come off? I need to remove the rear brake line for upgrade to a Galfer line.
There was some good info about differing bolt thread pitches on this thread and I do see Galfer includes two diff threaded bolts https://www.hayabusa.org/forum/maintenance-do-yourself/154667-rear-brake-line-removal.html
....but for now, how do I get the OEM banjo bolt off the caliper with that pointy thing on there?
I use a wrench! a 12mm!
From the factory they are very tight.
LOL, yeah, GIXER...12mm --I discovered the banjo bolts are really tight a couple days back. I took off my rear brake MC to paint it ...had to put it back on to turn that banjo bolt with a wrench! I couldn't get it holding the MC in my hand and wrenching on the bolt w/the other!!
What I was asking about however was the chrome bullet head that covers the rear brake caliper banjo bolt.
^^^Is that NOT OEM?
I found a set screw on the back. ..so trhat is how it comes off. It takes the smallest allen wrench. 1.5mm
Well then next time post a pick, because what you removed is not factory!
I was beginning t0 think not because no one was picking up on the "bullet head" description. My bike sat out in a showroom prior to sale. I guess they put a few little doodads on there and that must be one. I like it! Think I'll keep it!!
Thanks for help.
