Rear Fender Kit A-Tech
I have just finish installing the A-Tech rear fender eliminator kit.
KawAbuser great fit only took me less than an hour(would have been less but toomuch loctite on one screw)I will E-mail you with some Ideas.
Real clean look a must for a slick
Hi Johnnycheese,
Do you have any ideas on alternate rear turn signals? Have you looked into mounting the original turn signals by the opening near the rear passenger foot pegs?
Ride Safe,Bob
the best one I have seen is on my friends Busa.
he has used the two bulbs in the tail light as turn lamps aswell. He use a converter from a trailer shop and installed reflective tape between the two tail light bulbs,
Looks trick no turnlamps just a taillight.
I like my setup, which can be viewed at labusa tonight. I left about one inch of fender and sculpted the outer edges so they flow smoothly from the tailsection. Then mounted very high quality sealed marker lights for cars in the outer edges of the 1 inch of fender. They are about an inch wide and 2 1/2 inches long and sit flush. They are clear with yellow bulbs. You can see them clearly from directly behind the bike which is something you wont be able to do if you put them inside the holes in the tail. Last I molded my plate to fit around the fender perfectly. And drilled thru the center of the 1 inch of fender left. Used the little reflectors with wingnuts to mount the plate, they came in blue. Tell me what you think after seeing it tonight.
