just purchased a rear hugger/fender. the instructions say i need to drill a hole in the swingarm. anyone done this? i dont mind cutting plastic, but drilling into swingarm seems scary...thanks
i bought one that requires the original chain gaurd to be removed. from there, you put those two bolts back on, but need to drill the other side. what i did was just ran a strip of velcro on the right side instead of drilling, and it seems to work perfect...
I used heavy duty doublesided foam tape between the hugger and arm and also put a black zip tie around the outside of the brace and the hugger. Seems good so far.
here the extreme graphics hugger,,just bolted on, took all of 3 mins to install,,,,i have to take better pics just finished doing undertail and other mods,,,
