OB_BullDog
What performance are you looking for?
You will have more low end. I think 2 teeth on the rear is better than 1 tooth down on the front...easier on your chain!... You will now have a slightly shorter wheelbase than before unless you used a longer chain.
She should wheelie real easy now! and rev a little higher than normal...speedo will be out a little to...
