Rear Wheel Cotter Pin
Sloto200
Off we go, into the wild blue yonder...
I dont use a cotter pin anymore... these are easier to use and no cutting involved... you can pick them up at any hardware store... i got this one at harbor freight... and yes my tire is flat... picked up a 1/4 inch piece of razor blade in it this last weekend.... there goes my qualifier...
(bigoltool @ Apr. 05 2007,16:50) I use the same clip also but I have mine safety wired to the axle adjuster bolt so I don't lose it.
i keep forgetting to do that myself... i need to buy some safety wire and safety wire pliars too...
(Sloto200 @ Apr. 05 2007,15:40) I dont use a cotter pin anymore... these are easier to use and no cutting involved... you can pick them up at any hardware store... i got this one at harbor freight... and yes my tire is flat... picked up a 1/4 inch piece of razor blade in it this last weekend.... there goes my qualifier...
Why did you installed it on the left side of the bike?
(Vic_E55_2001 @ Apr. 05 2007,16:56)
It used to be on the right side... since i went to a single side exhaust it just makes it easier to rotate a breaker bar or ratchet or what ever without having to worry about hitting my exhaust can... i noticed that after i did it that all busas rear axle nuts are on the right side but almost every other bike you see out there its on the left side...
(bigoltool @ Apr. 05 2007,14:50) I use the same clip also but I have mine safety wired to the axle adjuster bolt so I don't lose it.
Or have some JERK come pull it out and walk off with it, while your eating at a Restaruant
(Sloto200 @ Apr. 05 2007,16:04)
Why did you installed it on the left side of the bike?[/quote]
It used to be on the right side... since i went to a single side exhaust it just makes it easier to rotate a breaker bar or ratchet or what ever without having to worry about hitting my exhaust can... i noticed that after i did it that all busas rear axle nuts are on the right side but almost every other bike you see out there its on the left side...[/Quote]
That makes sense. I actually switched from left to right on my TLR. much easier to adjust the chain.
(Sloto200 @ Apr. 05 2007,15:04)
Mines are same way...
(Vic_E55_2001 @ Apr. 05 2007,17:56)
my yoshi 4-2-1 install manual said to reverse sides to prevent "burns" if you had to work on the rear axel while having a HOT exhaust
