rear wheel sprocket question
johnny1980
I took the rear wheel off my 08 hayabusa because it is leaking air somewhere. When it is off is the rear sprocket just suppose to fall off or should it be still really tight on the wheel? thanks
yeah it just fell off then inside is the cush drives. Sound normal? because i watched other videos an it was still mounted
Thats what mine does, seems fine to me. Just pick it up, put it back on when you re-install the wheel. I think some are just tighter or stick to the rubber.
Replace the cush drive rubbers. They are cheap at your local dealer! It will tighten right back up! :beerchug:
