Rectifier Location
Nick6153
Hello all,
Could someone please post a pic of the correct rectifier location and wire routing?
Mine was shoved under the back seat when I bought the bike and I can't seem to find a spot that fits it right.
Thanks!
Nick
On a bracket that the little wing in front of the tire bolts to. I don't know anybody that still has their wing on.
Likely the previous owner removed the bracket and wing under your rear shock. You can purchase a bracket that is made by Adams from Schnitz racing or direct from Adams to mount on the right side of your rear sub-frame. It is $40.00 for the part including mounting hardware.
It used to live down here,as mentioned....but flat on top of the wing.
Rubb.
You guys are awesome - thank you!
I think I see what the previous owner has done now. There's a chunk of the rear inner fender just forward of the tail light cut out, which I'm guessing is where he had it mounted at one point. I'm gonna work tonight to see if I can make that location work and look a little neater.
