Reflector removal
Over_Easy
GEO-STABILIZATION EXPERT
Okay I removed the front reflectors and replaced each bolt...no problem.
Moved to the rear reflectors and discover the bolts have a nut on the inside.  I removed the bolts but now have loose nuts on the inside of the rear and can't get to them even after I removed the rear hump.  I can see one that moved toward the front but can't reach it.
How in the heck do you get these things out?
<!--EDIT|Over_Easy
Reason for Edit: None given...|1150144182 -->
Same problem here...:O
Pull down on the reflector as you turn the screw out.
You need to put seat pressure on the nut inside the fender.
remove the front screw on the tail section / separate the bridge by the latch / plastic rivets underneath will then allow enuf access
Guys, here is an easier method. If you will stick your hand above the tire and smack the undertail (not real hard) the nuts will bounce down to the front and out of the bike. No disassembly required.
Don
Heres a video I just made for ya on what bolts you will need r to remove on your rear section.
Tools needed: allen head screw driver to remove the first bolt I point to in the video that is capped with a black cap, a pen to push the push rivet or micro screw, phillip head screw driver, thats it.
When you get to your underside instead of having screw head holding the rear section to the underside (Black plastic or mudflap) as I do shown in my video, you will have plastic rivets that will need the center of it pushed inward to release. I also included a video for that as well. Also, your seat will have two allen head bolt and not a push pin type like mine.
Just repeat the steps in the video on the opposite side.
<span style='font-size:15pt;line-height:100%'><span style='color:red'>
Imporant note: Be sure to tape off the seat latch area after you unhook the quick release !!!!!!
</span></span>
<embed width="352" height="308" type="application/x-shockwave-flash" src="http://vidmg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v291/Rhythm_1/MOV03087.flv"></embed>
<embed width="352" height="308" type="application/x-shockwave-flash" src="http://vidmg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v291/Rhythm_1/MOV03088.flv"></embed>
<embed width="352" height="308" type="application/x-shockwave-flash" src="http://vidmg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v291/Rhythm_1/MOV03092.flv"></embed>
<embed width="352" height="308" type="application/x-shockwave-flash" src="http://vidmg.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v291/Rhythm_1/MOV03091.flv"></embed>
<!--EDIT|Rhythm
Reason for Edit: None given...|1150156801 -->
I also covered the four open holes by installing four plastic rivets I got from Lowes. Cheap and clean.
Nuts???... what nuts?
I will get them shits out when I change the undertail, if they are still there.....
