this is not true as a power commander doesn't actually set tables it only fools or tricks the already set tables in the bikes ecuyou have more flexibility setting the fuel and ignition tables with the power comander
in other words the bike is still in fact using its ecu maps then the power commander is compensating on that....you can do way more with the re flash....you cant raise your rpm limiter in power commander or turn on.off your hard/soft cuts ect ect....ask smithabusa he will tell you what you should do.....
+10000000000000000000000000000you guys need to do your homework. Greg smith of boostbysmith and david petrik's software the ecu editor is the most dynamic, cost efficent way to reflash what you already have and change or edit rev limiters, doing away for the need of a tre, use flapper solenoid wiring to control nitrous, just as a window switch. Etc, etc....... Dont believe me check out for yourself, go on greg's web site and view his interface products and what they can do for you using yor stocker ecu. Software is free and greg gives great tutorial help when you buy his product. Wait.you can always buy a pciii and the hub, igntion module, and all the other boxes dynajet slinging, and you still hve to use your stock ecu inconjuction with them ummm.
You guys need to do your homework. Greg Smith of BoostbySmith and David Petrik's software the ECU Editor is the most dynamic, cost efficent way to reflash what you already have and change or edit rev limiters, doing away for the need of a TRE, Use flapper solenoid wiring to control nitrous, just as a window switch. Etc, etc....... Dont believe me check out for yourself, go on Greg's web site and view his interface products and what they can do for you using yor STOCKER ECU. Software is FREE and Greg gives great tutorial help when you buy his product. Wait.You can always buy a PCIII and the HUB, Igntion Module, and all the other boxes Dynajet slinging, and you still hve to use your stock ECU inconjuction with them ummm.
If you are going to have Lee dyno it, trust him and take his advice!
What did he say about the TRE if he reflashes it?
why do you specifically point out the 02-07? i put a pc3 on my 01 with a full akra kil, airbox mod, k&n, tre and sprocket and it seems to have helped a lot
