Yes you use the rear reflector brackets. They mount in the stock rear holes from the fender, using the reflector screws. Then fit the plate up and mark the holes to be drilled in the reflector brackets not the plate. For the plate light I used those new license plate led bolt lights in dennis kirk part no. 21-2370, it looks great. Just use the stock wires for the plate bolt lights.
