Removing 186 restrictor?
gtrpimp76
S.Q.U.I.D. Extraordinaire
I'm not sure if this has come up but I'm sure it has. What is the best way to remove the 186 restrictor/limiter on the Busa without using a TRE, Smart TRE, or ATRE? I've downloaded the Service Manual from this site so if there's a way to do it please lemme know? I'll post in the technical section as well. Peace out y'all...
What a TRE?
im having mine done like this as we speak
http://fastcycles.com/powerbo....=2&t=34
A GPS MODIFICATION FROM POWERHOUSE
POWERHOUSE now offers their gear position switch modification to all their Hayabusa and GSXR customers . . . Your GPS resides behind your clutch basket. It is removed, modified, and reinstalled. The result? Your bike now has all of its different timing maps RESTORED. In addition, your original speed restriction is REMOVED, and you can also remove your TRE. Now your bike idles correctly, it does not try to backfire when you first start it in the morning, and your speed limiter is disabled. And, you will go quicker in the quarter mile.
THE BEST OF BOTH WORLDS . . .
now you know my mod $100.00 plus shipping
JC,
PM me for more info. Your deal sounds good!!
Sorry to bump this thread but I have a question for JC. Ive been talking to several tuners regarding my soon to be turbo setup. I want the GPS done b/c there's no point in having turbo if I've got speed/rpm restrictions. Does the GPS mod keep the maps in gears 1-4 intact so that gears 5 and 6 are similar or are all the maps entirely different. I've been hearing this mod makes it similar to the '99 models. Thanx.
so can a guy install this himself, or do I need my speed shop to do it for me? Im very limited with Busa stuff at this point...Im a newb.
5/6 same map as 5th
and yes
you could do it yourself I remove the clutch basket but I have never tried leaving it on and swapping it out
ok so JCs changes teh emc and the other guy changes teh gps behind the clutch basket?
No. The other way around. JC does the GPS behind the clutch basket and DaveO does the ECM. The Gear Position Switch has its resistors modified so the ECM reads 6th gear in the same map as 5th. 5th gear has no speed/rpm restriction from what I understand. Doing the GPS doesn't mess with the ECM's computer. Dave "reflashes" or "hacks" the ECM but you still need to obtain a TRE. I don't want the TRE b/c of the overly aggressive nature in gears 1-4 will have especially with a TURBO SETUP (I plan on a Hahn Stage 1 Racecraft with 8-10 lbs boost on pump gas to start). Should produce anywhere from 230-300rwhp so I do want to retard the ignition maps in the lower gears until I get aquainted with the power.
