Removing front reflectors
Scribbler
Just making a quick check before I remove the front reflectors... they are bolted to the front calipers. So I'm curious if I can just pull the bolt, remove the reflector and re-install the bolt. Or does the reflector itself act as a spacer for the bolt, thus perhaps requiring a washer to take it's place?
same here... no problem with just replacing the bolt!
