Just did my valve clearance check at 12k, getting ready for the nice weather to hit New England. Did the check early because of some top end clattering, that is prob normal. Anyway, all valves in spec. In the process I stripped the hex socket part of the cover over the starter clutch. It was practically welded on, and I never got it off. I finished the job but had to remove the whole cover to turn the crank. Thankfully the cover didnt crack, but it was a PITA to line things up.
Any ideas on how to free this up? I didnt want to take a torch to it and cook off the paint. I tried some penetrating oil with no luck initially. Not a big deal since hopefully won't be checking the valves for a while, just annoying.
Thanks
C
Thanks
C
