REPLACEMENT FUEL INJECTOR RUMOR
OB_tinhead
A good source (he's building a busa motor to go mini sprint racing) told me there are replacement fuel injectors available that fit the throttlebodies and do away with a lot of the need for Yosh boxes, PC2's, laptops, downloading maps, and other cybercrap. Has anybody else heard similar?
THanks GSX1300rguy. Could be just the place I'm looking for. I do have to realize that no rumor is as good or bad as heard, but there are usually kernels of truth in them.
gsx1300guy, that was a good dig. Interesting company that C&C, have you sent your injectors to them.
Actually have you spoke with them about the "cut out" problem we had?
[This message has been edited by KawAbuser (edited 24 December 1999).]
Actually I told him about the filter problems and low rpm roughness ,he checked into it and said he talked to a dealer and he said that our bikes have a standard Bosch type injector and it would be no biggie to clean ,flow and balance them.Which in turn should make a noticable improvement.I haven`t sent mine out yet...waiting till after the New Year.Going to talk to him again and see if he can do anything about the dip thats happening to the fuel pressure on the Busa`s or if they make a standard higher flow drop in .
[This message has been edited by gsx1300rguy (edited 24 December 1999).]
How can I contact C&C??
Injector size won't help unless you can't deliver enough fuel with what you have.
When you remap--i.e PC2 you increase/decrease the duration the injector delivers fuels. At some point it (modify motor-cams, etc) may may be needed.
Bob
But, if the injectors vary in flow on some sort of baseline they use, that could be an issue. Do they have a Bosch specs on our injectors?
Bob
gsx1300guy did he offer any information on the source of the brown "gook" in the filters? Is this a common substance that is in gasoline, any recomended fuel injection cleaners. Did you mention your inline filter fix for the Busa?
Who did you speak with, one of the C's?
