Towboater68
Hey guys,
i just started installing new rotors and pads for the front but i have a question. When i took the bolts off the rotor i had to put some REAL pressure to pull rotor off rim. Now i have the galfer rotor and it doesn't want to slide onto hub either. Ive watched some videos of non haybusa's disc removal and all of them the rotor just sits flat. When i put the rotor on the wheel it sits on the hub but does not slide down. Do you put the bolts on and actually pull it down with the bolts? is it supposed to slide right on?
